Thread: ACA 2008 & Annotation Scaling
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Default ACA 2008 & Annotation Scaling
    im not quite sure where to put this -
    having read about the dynamic annotation scaling in ACA 2008, does anyone know how that will work with annotation blocks & dynamic blocks? we arent using the AEC stuff, and as such we currently have quite a few DB's that we use, and it would be excellent if we would be able to apply the multiple scale factors to them, so multiple layers & blocks in the drawing arent required.
    This aggression will not stand. Man.
    2003-03
    Philadelphia, PA
    2,384
    Default Re: ACA 2008 & Annotation Scaling
    Quote Originally Posted by Chad_C
    I know next to nothing about dynamic blocks, but you can create regular AutoCAD blocks that are "annotative" and will change size with changes to scale. I would hope that the annotative scaling would be integrated with dynamic blocks.
    David Koch
    2006-04
    1,129
    thanks i am looking forward to finding out.
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,724
    We should have a forum to stick this into within the next week.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2006-04
    1,129
    from the help file (and this does work on dynamic blocks)
    Use this procedure to edit a legacy Architectural Desktop blocks, such as callouts or titlemarks, and add an annotative property.
    1. Open the legacy Architectural Desktop drawing in AutoCAD Architecture.
    2. Specify the same annotation scale in the new AutoCAD Architecture drawing as in the legacy Architectural Desktop drawing.
    3. On the Command Line, enter BEDIT to open the Block Editor.
    4. In the Edit Block Definition dialog, select the block to edit, and then click OK.
    5. On the Properties Palette, under Block, select Yes for Annotative.
    6. On the Block Editor toolbar, click Close Block Editor and then save your changes.
    Any blocks of the selected block style are now annotative.
  1. Annotation, Attribute and scaling
    By jpratt in forum AutoCAD Annotation
    Last Post: 2009-09-24, 05:33 PM
  2. Annotation family scaling?
    By TinCanFury in forum Revit - Platform
    Last Post: 2009-04-20, 06:32 PM
  3. Annotation Scaling
    By Binu Mathew in forum AutoCAD General
    Last Post: 2008-08-26, 02:59 PM
  4. Non-scaling annotation symbol
    By ErichB in forum Revit Architecture - Families
    Last Post: 2007-09-17, 06:37 PM
  5. Annotation Scaling (AutoCAD 2008)
    By Filipe Francisco in forum Português - AutoCAD / AutoCAD LT
    Last Post: 2007-07-05, 08:42 AM
