Results 1 to 10 of 10
Thread: Stretch by grip, grip becomes longer than the actual block
    2001-01
    213
    Red face Stretch by grip, grip becomes longer than the actual block
    Hi Everyone-
    I am currently working on numerous DB and I have encountered a strange thing with one of them and that is that whenever I stretch the block the grip that I select seems to grow longer then the block itself. I have looked and looked at all the parameters and I cannot find the one that is affecting this entity. I am attaching a copy of the block for your review. Thanks.
    Manuel A. Ayala
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Stretch by grip, grip becomes longer than the actual block
    Quote Originally Posted by cadconcepts
    Hi Everyone-
    Manuel A. Ayala
    interesting. after using 'dwg true convert' (so i could check this out from home in A2006) and after going into the BE to look at the radiator, every time i click on the bottom stretch action, i bomb out with an 'internal error'... twice!.....
    i'll see what happens in A2007 tomorrow...
    S&D DB Sharing Forum
    AUGI Addict Mr Cory's Avatar
    2007-01
    Under a Rock over there
    1,006
    Delete the linear parameter as there is some funny with it, create a new linear parameter and dbleclick on the actions to associate them with the new linear parameter.
    Not sure why the parameter is playing up sorry but recreating it seems to fix the problem
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Quote Originally Posted by Mr Cory
    Recreating the parameter fixes this issue - Cory is right.
    I've had this happen before. I have no explanation as to the WHY. All I know is that sometimes parameters simply wake up on the wrong side of the bed.
    Regardless, here is a fixed version of your block.
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    2001-12
    Rochester, MN
    2,561
    i NEVER use the pre-grouped parameter and actions for this reason, i ALWAYS start from scratch and have very few problems, especially when trouble-shooting...
    2007-01
    1,006
    Yea you have a good point there Chris, might do that in the future lol
    2001-12
    Rochester, MN
    2,561
    i almost gave up on DB's that first week i played with building my own because of those 'pre-assembled' options in the Authoring Palette. I was able to figure out what was going on WAY better when i started from scratch.
    2007-01
    1,006
    Do you create the parameter and action seperately? Usually i create the parameter and dble click on it to get the option for the type of action.
    Lol now that would have been interesting if you had lol
    2001-12
    Rochester, MN
    2,561
    yes, exactly that.
    Last edited by Chris.N; 2007-03-21 at 09:22 PM. Reason: clarified answered question....
    2007-01
    1,006
    I see i see. Each to their own
  1. Stretch grip works only at visibility stage 1
    By vessela.raybosh in forum Dynamic Blocks - Technical
    Last Post: 2010-05-25, 12:29 PM
  2. Stretch Grip 150 feet away from inserted block?
    By zorroxxxx in forum Dynamic Blocks - Technical
    Last Post: 2006-10-27, 01:58 PM
  3. Replies: 5
    Last Post: 2006-07-11, 04:28 PM
  4. stretch 2 directions with 1 grip?
    By sgoodmansen in forum Dynamic Blocks - Technical
    Last Post: 2006-03-22, 03:24 PM
  5. Dynamic block stretch in both directions from one grip?
    By kb3cxe in forum Dynamic Blocks - Technical
    Last Post: 2005-11-03, 10:11 PM
