Results 1 to 7 of 7
Thread: How to Use Images As Materials
    Smile How to Use Images As Materials
    Hi.
    First off, can you use jpegs/gifs as materials to attach as textures on objects in Viz?
    If you can, can someone please tell me how? I've made a picture frame in autocad and have imported it to Viz for rendering. i want to attach a picture in it.
    Or can someone please tell me how to do it in autocad instead? If it will be easier. Thanks!
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Default Re: How to Use Images As Materials
    Quote Originally Posted by frostxandxash
    Hi.
    You can use mapping inside AutoCAD.
    View --> Render --> Mapping
    Design Visualization Moderator stusic's Avatar
    2004-10
    Denver, Colorado
    1,515
    Hi.
    You'll get better results doing it through VIZ than AutoCAD. By using UV mapping, you can set any bitmap as a texture. I say use UV mapping because it gives you a bit more flexibility than mapping it through your diffuse channel.
    For specifics on how to do that, I'll refer you to the Help section of VIZ; they'll do a much better job of describing the steps than I would (especially since I"m using Max).
    Hope this helps!
    Regards,
    I could stop if I wanted to de-co1's Avatar
    2005-07
    Jhb - ZA
    274
    Viz and Max are pretty much the same, and the process of applying materials and adding JPGs to materials is the same.
    I don't quite know what you mean Stusic, by using UV mapping instead of Diffuse. I always understood it that you create your material through your material editor, adding the image to your diffuse channel.
    You apply your material to your objects, but you need to apply the UVW mapping modifier to the object. This way you can manipulate the size and orientation of your material on the object, and so your material can take on different settings for different objects.
    For rostxandxash's question, I would create a material, adding the image to the Diffuse channel. the picture object would just need to be a plane. Apply a UVW Map modifier, also set to plane, so that it matches the object, and then apply the material.
    HTH
    2004-10
    Denver, Colorado
    1,515
    Quote Originally Posted by de-co1
    Yep, I read my post and it didn't make any sense. I was ineffectively trying to advise they use the UV mapping modifier, and not just putting a bitmap in the diffuse channel. Bravo.
    2005-07
    Jhb - ZA
    274
    Quote Originally Posted by stusic
    Yep, I read my post and it didn't make any sense...
    No problem... I became a bit worried there myself, and thought there was something new I didn't know about!
    Smile Re: How to Use Images As Materials
    Thanks a lot guys! I was finally able to do it!
  1. Slide Shows of Images and Drawing Images
    By peter in forum Bridging the Gap: LISP -> .NET -> LISP
    Last Post: 2014-01-25, 08:12 AM
  2. 2012: Ghost Images and Lines On-Screen and in Exported Images
    By cwride in forum Revit - Plotting/Printing/Exporting
    Last Post: 2012-08-15, 08:49 PM
  3. Revit materials replaced by Max materials, upon import
    By narlee in forum Revit - Rendering
    Last Post: 2010-07-09, 01:59 PM
  4. Adding own jpeg images for materials use?
    By Hulston1982 in forum Revit Architecture - General
    Last Post: 2008-01-15, 11:20 AM
  5. Assign rendering materials to revit materials?
    By dtownsend in forum Revit Architecture - General
    Last Post: 2007-05-03, 09:20 PM
