Thread: lidar surface keeps crashing Land Desktop 2007
    2006-03
    2
    Default lidar surface keeps crashing Land Desktop 2007
    I've been working in 2007 on a project with several design surfaces and a lidar surface (build from an XYZ point file, sampled at 1m). I have used this point file in the past to build the same surface in AutoCAD 2006 with no problem. However, each time I try to build the surface in 2007 it crashes my drawing. So, for now I've been building the lidar surface in 2006 and copying the DTM folder into and 2007 project to calculate my volumes. Needless to say this is less than ideal. Has anyone run into similar problems with large surfaces in 2007? I have used GIS software to clip the surface down to just the areas that I need, and I don't want to re-sample the surface and loose any resolution. Any suggestions would be great.
    Also any suggestions of better, more efficient ways to work with lidar would be great.
    Thanks
    13,654
    Default Re: lidar surface keeps crashing Land Desktop 2007
    Hi "brooke.107938"
    Please note I have *moved* this thread from the CAD Standards forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
  1. Adding Menus in Land Desktop 2007
    By fmertz.118882 in forum Land Desktop - General
    Last Post: 2007-05-08, 02:45 PM
  2. Images won't print in Land desktop 2007
    By jbbarrus in forum Land Desktop - General
    Last Post: 2007-04-20, 06:07 PM
  3. Do I need to activate Land Desktop Companion along with Civil 3D 2007
    By Chris.Partin in forum CAD Management - General
    Last Post: 2007-03-21, 05:15 PM
  4. Problems between AutoCAD 2007 and Land Desktop 2006
    By Chris.Partin in forum Land Desktop - General
    Last Post: 2006-12-14, 09:53 PM
  5. TEXTMASK in Land Desktop 2007
    By christinep in forum Land Desktop - General
    Last Post: 2006-10-11, 10:09 PM
