Results 1 to 10 of 15
Thread: Scaling the same Modelspace Objects at different scales in Paperspace
    Default Scaling the same Modelspace Objects at different scales in Paperspace
    I have a lot of objects in my global layout ( a big building with electricity, fire-prot. ... etc.), witch is why the drawn objects are rather small .
    Some splited layouts end up as a big building drawing with only a few small objects.
    So I'm looking for a way to scale them in the layoutview without drawing them all over again. This means the same element small in one layout but big in an another same sized layout.
    I don't know if it is possible but if there is a way please let me know.
    paul
    ATP Manager CADKitty's Avatar
    The Dragon's Lair
    731
    Default Re: Scaling the same Modelspace Objects at different scales in Paperspace
    So you have everything drawn in model space, correct? Is it set up to a certain scale (1/8", 1/4") or 1:1? If you have blocks not scaling up in scaled viewports, are your blocks set to be relative to the drawing scale?
    I drink coffee for your protection.
    Windows 7 | AutoCAD 2017 | Revit 2017
    Everything drawn in model space 1:1 including a building Xref.
    But what I realy want to do is; starting from the same model
    - create a layout
    - and create another layout identical to the first one but with some elements in a larger scale in their exact position.
    It would be handy for our security people. That way all the required information can be printed on a A3 sheet instead of a big unhandy A0.
    Thanks for the quick responce. paul
    The Dragon's Lair
    731
    Quote Originally Posted by paul.vanvlasselaer
    - create a layout
    Ahhh...hmm...around here we have to scale the blocks up in model space to get them to come out right (we do a lot of enlarged plans). Is this plan going to be changing often still? When we do our enlarged plans we'll actually put the different scaled things on a different layer. Mind you, if your stuff is going to keep changing, that's gonna be a royal pain.
    Propably be changing very often.
    I'll think it over in the weekend.
    Hoping for a AHA grz.
    0,0,0 The Origin
    8,570
    I assume these objects are symbols, not geometry that looks like the actual objects?
    In that case, CADKitty's suggestion of duplicate symbols on a separate layer is probably the best.
    2005-07
    2,356
    if the symbols are blocks then I suppose it would be possible to have small and large scale symbol in the same block but on different layers, then turn the layers off as required in each viewport, still a bit longwinded though.
    Edit: Actually I think I've said the same thing as Kitty
    Active Member Cadtharsis's Avatar
    2006-02
    Pi World. It's not what I was thinking. :(
    90
    Certainly sounds like the smoothest way. Should be easy enough to make changes once it's set up.
    Seems promising
    2005-06
    in the upper right corner
    3,523
    Red face Re: Scaling the same Modelspace Objects at different scales in Paperspace
    If those symbols are blocks, another suggestion would be to create an xref base of just the symbols, scaled accordingly.
    Then "save as" to a seperate xref base for the different scale in which you do a global scale change of all the blocks through the properties dialog.
    Then, as things change and move, modify the main symbols xref base, and then save over the other one and repeat the global scale thing.
    That way you're only dealing with one set of blocks and just changing the scales on the other symbol base.
    Just a thought.
  1. Replies: 13
    Last Post: 2014-12-08, 03:56 PM
  2. Replies: 11
    Last Post: 2010-11-11, 10:32 AM
  3. Move Objects from Paperspace to Modelspace and vice versa
    By thechinaman in forum AutoCAD LT - General
    Last Post: 2007-03-13, 05:45 PM
  4. Replies: 9
    Last Post: 2007-01-10, 09:28 AM
  5. Linetype scales between Modelspace and Paperspace
    By dcornelius in forum AutoCAD General
    Last Post: 2006-12-18, 06:22 PM
