Its the simplest of things that get me.
I'd like to align the footing like the red dashed line shows. It appears almost locked to the wall.
If it is a Wall Foundation - it is attached to the wall. You may need a Foundation slab in this instance....Originally Posted by scowsert
You could also create 2 new wall foundation types. Set the Structural Usage type parameter to Retaining instead of Bearing and adjust the Toe and Heel Length parameters to get everything lined up.
