I'd like this wall to go all the way up. According to the properties of it should. Somehow I've attached it to the bottom of this slab. How do I unattach it?
Thanks guys.
Thanks guys.
1. Select the wall(s) you would like detached.
2. On the options bar select Detach, then Detach All.
Typically whenever you add or edit a slab in Revit you will be asked upon finishing the slab sketch: "Would you like the walls that go up to this floor's level to attach to its bottom?" I typically answer No in most cases. My guess is that you answered yes at one point.
Thanks Paul that did the trick. I think I'm starting to get the hang of this.
