Results 1 to 6 of 6
Thread: Wall Component Schedule
    2004-06
    Port Moody, BC
    349
    Default Wall Component Schedule
    I am looking to form a schedule for my walls where I show the name of the wall type followed by a list of the materials from exterior to interior, so far I have got to the stage of creating a material takeoff and including the fields for Type, Material:Name, but this then itemizes every components within the drawing, so if I have 7 components in a wall type and this wall type exists 75 times then my schedule has 525 lines, 518 more than I want.
    I am looking for a setting to only include one of each family type I have in the drawing I guess.
    Thanks
    100 Club Overconstrained's Avatar
    2005-05
    Hamilton NZL
    158
    Default Re: Wall Component Schedule
    Under the "Sorting/Gouping" tab in your schedule properties uncheck "Itemise every instance" at the bottom of the tab.
    Does that help??
    2015-12
    Vancouver, BC Canada
    3,753
    What you are describing sounds like a wall legend. Take a look at legend views in the help file.
    The bad news is you can't automatically get the list of all the elements in the assembly but the good news is, once you've typed all the text in you can re-use the legend view from project to project.
    2004-06
    Port Moody, BC
    349
    Thanks Dimitri, so just to confirm, there is no way to ensure that all the wall family types used in a project are in the Legend, its a manual process of dropping in the legend components then placing text next to them. If the wall structure changes then you have to remember to manually modify the wall legend as well? If a new wall structure is created then you need to add this to the Wall Legend view?
    Drew
    2004-06
    Port Moody, BC
    349
    Thanks Overconstrained. I have managed to get fairly close to the requirement by showing the fields "Type" and "Material:Name", then sorting first by Type (Ascending - Header - Blank Line) then by Material:Name (Ascending) and not itemizing every instance, but this just sorts the wall components alphabetically, I would have like to sort them by wall location.
    Thanks
    Drew
    2006-03
    London, UK
    810
    Not possible, AFAIK - I tried for a while to do this, with all sorts of fancy filtered schedules and things. Should be easy enough to implement in the program, but we'll have to wait for them to do it.
  1. Replies: 2
    Last Post: 2015-02-23, 03:08 PM
  2. Schedule a Detail Component family?????
    By Joshua Kohl in forum Revit Architecture - Families
    Last Post: 2014-10-07, 09:20 PM
  3. schedule + detail component + graphics
    By Ning Zhou in forum Revit Architecture - Families
    Last Post: 2010-08-31, 03:34 PM
  4. Ability to schedule wall component data
    By ted.evans in forum ACA Wish List
    Last Post: 2007-08-13, 08:54 PM
  5. Circular Wall Reveal as Wall Component
    By artitech in forum Revit Architecture - Families
    Last Post: 2005-06-12, 08:28 PM
