Interesting.... what you did seems to have fixed what was going on. You said just the Flatten command did it for you?
When I invoked it, it said "Invalid keyboard input" or something similar after I selected my objects via a window.
Now I go and invoke it and the following happens:
Command: flatten
Initializing...
Select objects to convert to 2d...
Select objects: Specify opposite corner: 183 found
Select objects:
Remove hidden lines? <No>: y
No translatable objects.
Command: re
REGEN Regenerating model.
Command:
Check out the attached file! I created a masterpiece in seventeen dimensions!
