Results 1 to 6 of 6
Thread: AutoCAD 2006 - Unable to move Attribute Text via Grips
    2005-07
    6
    Default AutoCAD 2006 - Unable to move Attribute Text via Grips
    Hi Everyone,
    Firstly, I did a search and couldn't find anything specific to my question so my apologies if the answer exists and I didn't find it.
    My question: A particular drawing I am working on had the attribute text grips displayed and I was able to re-position the attribute text independently of the block. I must have done something that caused the grip to disappear and now I have to move the attribute text using -ATTEDIT. Can anyone tell me which setting I need to change to get the grips back? Thanks!
    -Andrew
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: AutoCAD 2006 - Unable to move Attribute Text via Grips
    Quote Originally Posted by andrew.90224
    Hi Everyone,
    -Andrew
    is the block dynamic? if so, the attributes may have their positions locked, which would remove the ability to relocate with the node.
    S&D DB Sharing Forum
    2005-07
    6
    Quote Originally Posted by Chris.N
    Ok..I have a bit more beta on my situation. I just realized that I had the drawing open in AutoCAD 2000 so I re-opened and the attribute grips are there. This is not the case when I open in the current version I am using which is 2006.
    Chris, I am not sure if it's a dynamic block...how can I tell?
    -Andrew
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    -Andrew
    Hi Andrew,
    Also, if the attribute was created with the "Lock Position in Block" option checked in attdef, it will do that. You may need to explode the block, change the "Lock Position" property (under Misc in the properties palette) to No for the attribute, then redefine the block. I'm not sure if that option was avalilable in 2000 (I don't remember), so it may be what you are running into.
    HTH
    Tim Creary
    S&D
    DILLIGAF
    13,656
    Hi
    If the Attribute Text does belong to a Dynamic Block, you may wish to take a look at the following...
    ID: TP5567606 - Dynamic Block Attribute Locking
    Have a good one, Mike
    2005-07
    6
    Hey,
    Thanks for the tips! I'll look in to this stuff and let you know how I do!
    -Andrew
  1. attribute text doesnt want to move
    By janderson664783 in forum Dynamic Blocks - Technical
    Last Post: 2012-07-24, 02:22 PM
  2. Unable to save edited Attribute Text
    By rw4 in forum AutoCAD Fields
    Last Post: 2008-10-15, 03:59 AM
  3. Unable to move objects in AutoCAD
    By chrisr in forum AutoCAD General
    Last Post: 2007-10-11, 02:50 PM
  4. AutoCAD 2007 unable to move Tool Palettes
    By vtmiii in forum AutoCAD General
    Last Post: 2007-01-11, 07:14 PM
  5. Replies: 3
    Last Post: 2006-04-04, 05:46 PM
