Is there a way to make AutoCad use all caps while doing everything?
And,
Can the computer revert to "Caps off" outside of AutoCad?
And,
Are you going to tell is all how, or leave us in suspenders?Originally Posted by Ed Jobe
other than using the "Caps Lock" key?Originally Posted by Robert.Hall
In Mtext if you right click on the window and turn autocaps.
AutoCAPS
Converts all new and imported text to uppercase. AutoCAPS does not affect existing text. To change the case of existing text, select the text and right-click. click Change Case.
I think there is a lisp routine on the exchange called allcaps.lsp that will convert existing text.
there is an express tool that will change the case of existing text.Originally Posted by McDonaldRi
But nothing to put your text into "Sentence case" or "Title Case".
there is something on the exchange... see this thread.
http://forums.augi.com/showthread.php?t=6392
in ADT 2007 (i dont know about earlier versions) - express tools has tcase which will change text case just like the tool in Word.Originally Posted by carl_hd_collins
Someone at another forum did just that with a little program he wrote called "capsman.exe".Originally Posted by Robert.Hall
http://www.theswamp.org/lilly_pond/k...an.exe?nossi=1
and the post:
A person who shall remain nameless ...
« Reply #7 on: 2005-04-08, 05:20:41 »
Reply with quote Ok, boys and girls ... here is the very first incarnation ... well if you count the code above, it is the second. I had to do alot of changes to the code so it would work properly in other Windows platforms, but credit for the original idea goes to MP.
The premise is that when a window becomes active it notifies the OS, we can intercept those calls with a simple timer, get the active window, determine what application it is from, and if it is AutoCAD, turn Caps Lock ON if it is a browser window, turn Caps Lock OFF. Well, that is how it is SUPPOSED to work.
I don't have FireFox installed here unfortunately so I am not able to verify it working properly with it. If anyone has a problem with it working properly send me a screenshot of the browser window or AutoCAD window and I will attempt to resolve the problem.
And give me some feedback ...
Enjoy .. I know that I am going to use it...
I think you would have to join to download it. It works well for AutoCad, browser and Outlook Express.
