Thread: Category Parameters (ex "Offsets")
    2006-12
    Default Category Parameters (ex "Offsets")
    Does anyone have experience with the various parameters that are evident a family within Revit Systems when a family is placed? Are these based upon the category? So, then, if I go in and alter the category, it should be inherent to those category settings (leastwise, I would think) and as a result, change by category setting? This doesn't seem to be the case. I'm wondering, does it only change based upon the category in which it was originally created? - or does it depend upon the template utilized for creation? - or is there another way in which this may be altered? One of the parameters I've noticed this with is the "offset" constraint.
    All AUGI, all the time JoelLondenberg's Avatar
    2015-10
    508
    Default Re: Category Parameters (ex "Offsets")
    It's a bit hard to understand what you are referring to. Can you post the family?
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    890
    I think she is referring to part type parameters. As far as I know, parameters such as "mains" on an electrical panel board type family are hard coded into Revit and cannot be changed or deleted as far as what kind of parameter they are.
  1. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  2. Equivalent of ETABS "end offsets" in Robot
    By strozy in forum Robot Structural Analysis
    Last Post: 2010-06-22, 02:53 PM
  3. schedules: insert "-" or "n/a" for parameters with no value?
    By timsea81 in forum Revit MEP - General
    Last Post: 2010-03-24, 06:58 PM
  4. "Author" & "Checker" titleblock parameters
    By jhectorne in forum Revit Architecture - General
    Last Post: 2010-01-20, 12:16 PM
  5. Globally Revert Linework to "By Category"?
    By 3dway in forum Revit Architecture - General
    Last Post: 2009-02-04, 06:17 PM
