Thread: "Breaking" Survey Figure lines
    2007-04
    3
    Unhappy "Breaking" Survey Figure lines
    Is it possible to "Break" or delete a section of your figure line that was imported through a field book? There dosen't seem like there is an easy way to edit these figures once they are inserted into the drawing. Will I have to go back and edit the field book file? Will I have to erase the error line and replace it with a figure line that I have to re-create? There has to be a easier way right? Any help with this would be greatly appreciated?
    Thank you very much,
    Will
    2006-12
    Loveland, CO
    734
    Default Re: "Breaking" Survey Figure lines
    As far as I know, there is no way to edit a figure in a drawing. The only thing I've heard of is to edit the field book file and then re-import it.
    2007-04
    3
    Yah I was messing with that earlier and it did work. But it seems awfully cumbersome to do it that way. I figured there was an easier way of modifying these figure lines. Thanks Brian for your advice I guess that is the way we will have to do it until this issue is addressed.
    Thanks again,
    Will
    2006-12
    Loveland, CO
    734
    Will,
    You can check out some third party apps that I've heard good things about (haven't actually used them though) such as www.rsteltman.com and www.cadaps.com.
  1. CV234-3P: "Field to Finish": Sculpting a Better Figure
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2018-04-08, 08:34 AM
  2. Replies: 4
    Last Post: 2014-01-01, 07:58 PM
  3. does anybody actually use Survey Figure lines
    By McQueen960067 in forum AutoCAD Civil 3D - Survey
    Last Post: 2013-03-20, 11:15 PM
  4. Replies: 8
    Last Post: 2006-08-04, 10:18 PM
