Hi all,
The variable TABLEINDICATOR in my drawing is set to 1 but when i double-click
inside a table cell, the labels across the left side abd top do not appear.
Am i missing something here?
Using AutoCAD Map 3D 2007.
Cheers
Hi all,
Cheers
Hi
Is this issue / problem occurring in all drawing files OR just the odd one or two?
Have a good one, Mike
Mike,
This happens in every drawing!
Cheers
HiOriginally Posted by mark.shoesmith
Can you please post a drawing file for us to look at... we can then try and determine if the issue / problem is drawing based OR AutoCAD based (be it Hardware / Software / User based) OR...
We have never been able to see these either. In any drawing. If someone has any answer I would sure appreciate you posting it here.
We have a few summary of quantities sheets that we grab totals from one table and populate a different table (all in model space) and then we do viewports to show each table in the titleblock in a layout tab. If would sure be alot easier to track if the column and row numbers showed up.
Daryl
All
I opened the drawing with the table in vanilla AutoCAD 2007 and AutoCAD 2008 which
we have in other divisions in my office and the rows and columns show up when i edit the table.
Then i opened the drawing up again in AutoCAD Map 2007 and when i edit the table they do not show up.
So my computer has a problem with a setting somewhere??
Many thanks
Hi MarkOriginally Posted by mark.shoesmith
Given the above information (it would appear to be a Map 3D issue / problem), I have therefore moved this thread from the AutoCAD Tables forum to here.
Thanks, Mike
Forum Manager
But in LDT2007 it works. Also note that with C3D & Map3D 2008 the tabletoolbar varible settings have no effect and acts just like the tableindicator.
so you concurr this is a Civil 3D /Map 3D vertical problem. I don't think AutoDesk is aware of it. I am using SP2 for Civil 3D 2008 and it still does not work. also does not work in SP3 Civil 3D 2007
