Results 1 to 10 of 20
Thread: Mysterious running Intersection Snap?
    2003-03
    Brenham, Texas
    74
    Default Mysterious running Intersection Snap?
    I have some sort of running osnap in acad that I can not find the option to turn it off.
    It is new to me, we just upgraded from 2006 and I did not see this.
    I have attached a image showing what looks like a intersection osnap, but it is something else.
    Has anybody else found a way to turn this off?
    It does nothing and is just an annoyance.
    Member nbowley's Avatar
    2005-05
    Glen Burnie
    36
    Default Re: Mysterious running Intersection Snap?
    Command: pdmode, enter, 0, enter
    I am pretty certain pdmode is the cause.
    Changing it to zero will leave a dot instead of a big X if you set pdmode to one (1) the points will be invisible.
    You can also use the pdsize variable to make the X smaller and less intrusive if you decide you still want the X to show up.
    2003-03
    Brenham, Texas
    74
    I tried the pdmode and it was set to 0.
    What else do you think that I should try?
    2005-07
    2,356
    Try turning off BLIPMODE.
    2003-03
    Brenham, Texas
    74
    Blipmode is turned off.
    Any other suggestions?
    AUGI Addict Augi Doggie's Avatar
    2002-01
    Orlando, FL.
    1,348
    Quote Originally Posted by tbedrich
    We can't suggest much else without having the actual file.
    Those look like points, hence the pdmode suggestion. Can you select them and list them?
    0,0,0 The Origin
    8,570
    It doesn't look like a blip, a point or an osnap. Can you select it?
    13,657
    Hi
    It almost looks like the Parallel Object Snap with the two very faint lines going through the grey Hidden (vertical) Line, just above the yellow Continuous (horizontal) Line.
    Have a good one, Mike
    2003-03
    Brenham, Texas
    74
    I can not select them.
    When I regen they stay on the screen, Also when I zoom out a little and regen they move to a different location, and them when I zoom out further they go back to original location.
    0,0,0 The Origin
    8,570
    The fact that they move, then move back could point to a graphics card/display driver problem.
    Is this only on one pc? Do you have access to another pc?
  1. Make running osnaps always snap to the nearest matching snap point
    Last Post: 2012-06-17, 05:54 AM
  2. Intersection Snap on Solids
    Last Post: 2009-02-01, 04:36 PM
  3. can't snap to intersection
    By jodi_sherrell in forum ACA General
    Last Post: 2008-10-28, 07:06 PM
  4. Make the apparent intersection snap work on AEC objects
    By gdaniels in forum ACA Wish List
    Last Post: 2007-09-13, 10:46 PM
  5. Replies: 1
    Last Post: 2005-04-04, 02:55 PM
