Thread: 3D orbit
    2006-12
    Big "D"
    3,711
    Default 3D orbit
    When I have a viewport in ACA 2008 and use 3D orbit to rotate the view to a perspective, no matter what visual style I use, it looks X-ray. It's not the full X-ray mode (that is turned off), but the walls are somewhat transparent and I can see walls and windows that should be hidden. Any ideas?
    I think its a setting somewhere. The same drawing was started in ADT 2007, and I was having save and viewport issues. I copied it to an ACA 2008 template, and that's when it started. The new drawing based on the 2008 template does it in 2007 now. On a brighter note, I think the save and viewport issues have been fixed!
    2006-12
    Big "D"
    3,711
    Default Re: 3D orbit
    Just an update. I sent it in to Autodesk support, and the template got corrupt upon loading, which messed up the drawing. I started with a new template (same name as before), and re-inserted the drawing and everything is fine.
  1. 2008: 2d orbit.
    By cadgiri in forum AutoCAD General
    Last Post: 2012-12-01, 11:27 AM
  2. 3D ORBIT TARGET
    By richardronan in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-10-15, 07:52 PM
  3. Center Orbit Pivot with orbit tool
    By joe.williams in forum Design Review - Wish List
    Last Post: 2008-07-28, 08:55 PM
  4. 3D orbit in LT?
    By Jordan Truesdell in forum AutoCAD General
    Last Post: 2008-05-14, 01:46 PM
  5. 3D Orbit
    By cconner in forum AutoCAD General
    Last Post: 2006-03-01, 05:51 PM
