Thread: AutoCad Architecture 2008 - creating a slab on grade w/ haunch and interior fndt.
    Member dennis.wish's Avatar
    2006-11
    La Quinta, CA.
    9
    Default AutoCad Architecture 2008 - creating a slab on grade w/ haunch and interior fndt.
    I need some help on this one since I am sticking with Architecture 2008 due to the cost of migration. I expected a major change in the way slabs work in AA 2008 but am frustrated that when using the slab on grade feature from the content browser I was unable to adjust the depth and width of the turned down edge.
    I am looking for information or help to create a 3D slab on grade with a turn down exterior edge that is 6" above grade and 12" below with a 12" width for the bottom of footing. I also want to add interior foundations to support bearing walls and would like some info on how to work in AA2008 to accomplish this.
    Can anyone help me with this?
    Thanks
    Dennis
    2001-03
    38
    Default Re: AutoCad Architecture 2008 - creating a slab on grade w/ haunch and interior fndt.
    You can create the perimiter beam by creating a custom slab edge style and attaching it to your slab style. I have yet to figure out how to create footings in the field of the slab, it may not be possible yet. I have also been looking for this.
    2002-09
    Madison, WI
    5,688
    I believe there are some examples in the Styles Forum.
  1. Replies: 0
    Last Post: 2011-01-27, 07:02 AM
  2. slab-on-grade with gravel and thickened slab edge joining
    By t1.shep in forum Revit Architecture - General
    Last Post: 2009-11-23, 04:04 PM
  3. HELP!! AutoCAD MEP 2008 to Revit Architecture 2008
    By Dr._House in forum AutoCAD General
    Last Post: 2007-09-01, 06:06 PM
  4. Cross-Grade ACA 2008 to revit Arch 2008
    By tmao in forum Revit Architecture - General
    Last Post: 2007-04-20, 06:45 PM
  5. edge of slab on grade condition
    By 3dsketcher in forum Revit Architecture - General
    Last Post: 2006-08-02, 03:55 PM
