I added this post to the Autodesk Discussion Groups a couple of months ago and have not had any solution. Can someone please help?.......
My company recently replaced its colour printer/copier with a Konika Minolta C250. The printer works great, except when plotting particular files from AutoCAD (LT 2007).
I've had the problem with 4 different files, all of which have jpeg images inserted with other vector data overlayed. When I try to print these files, it takes an age to spool, sometimes a half hour, and when the print finally comes out the image is shifted under the vector data and is cut off with a jagged zig-zag edge.
I have plotted other files successfully, even though they have been setup the same way (same raster file type, etc.).
The Konica Minolta tech support has looked at the files and determined that "it seems to be an Autocad issue. He has told me that it is hanging in the application not the printer, which tells him that it is not the printer".
