Thread: Unloading Acopm.arx in 2004
    2003-06
    3
    Thumbs down Unloading Acopm.arx in 2004
    Apparently there is an undocumented feature in AutoCAD 2004 which does not allow the unloading of Acopm.arx (Properties Manager)
    When attempting to unload in 2004 an
    "Unhandled Exception C0000005 (Access Violation Reading 0x0000) at address 0h"
    occurs. This is not a problem in 2002 or 2005.
    Does anyone know of a fix for this problem?
    Thanks
    Don Sauvage
    2015-12
    Arizona
    2,478
    Default Re: Unloading Acopm.arx in 2004
    Another unrelated document suggests that one
    might be able to work around this issue by
    renaming or moving the location of Acopm.arx.
    Thus causing it to fail to load initially.
    2003-06
    3
    Unhappy Re: Unloading Acopm.arx in 2004
    Michael,
    Thanks for your response. I was hoping that someone with AutoDesk would respond and at least acknowledge this problem. It can be replicated on every R2004 Installation here (250+ seats)
    Don
  1. Unloading usubrs
    By JaCAD in forum AutoLISP
    Last Post: 2012-12-01, 03:49 AM
  2. Totally Unloading C#
    By CadDog in forum Dot Net API
    Last Post: 2010-05-19, 08:20 PM
  3. RVT links unloading by themselves!
    By ftonelli in forum Revit MEP - General
    Last Post: 2009-05-22, 05:56 PM
  4. Unloading Unreferenced X-refs
    By kerrysummers in forum AutoCAD LT - General
    Last Post: 2008-02-08, 10:41 AM
  5. Menu's unloading themselves
    By shona in forum AutoCAD LT - General
    Last Post: 2004-10-05, 07:05 AM
