jaberwok
Hi. Is this now an A2007 question?
3drotate is a known command in A2007 and the pgp file contains "3R" as an alias.
From Help -
"Command entry: rotate3d
It is recommended that you use the grip tools available through the 3DMOVE and 3DROTATE commands to manipulate 3D objects. For more information about using grip tools, see Use Grip Tools to Modify Objects.
Select objects: Use an object selection method and press ENTER when you finish
Specify first point on axis or define axis by [Object/Last/View/Xaxis/Yaxis/Zaxis/2points]: Specify a point, enter an option, or press ENTER"
