Thread: Custom Tags
    2003-02
    Question Custom Tags
    I would like to create custom tags for windows, door and spaces, and have them report to schedules. I have tried using the ADT help file "Creating AutoCAD DesignCenter schedule tags" but I do not get a tag that reports to a schedule, it just appears as an attribute block. Not sure what I am doing wrong, can anyone offer some direction on how to create custom tags? I'm thinking I am doing something wrong with the propertysetdefinitions part of the creation.
    I really appreciate you help!
    Cheryl
    2003-03
    Philadelphia, PA
    2,376
    Default Re: Custom Tags
    To learn more about Property Set Definitions, Schedule Table Styles and Custom Tags, take a look at Brain Dumps No. 13 and 15, by Mr. Matt Dillon, at http://home.earthlink.net/~ccyanchar/ .
    These were written for ADT2, so items added later, like style-based Property Set Definitions and the new automatic properties added in ADT2004 are not covered, but if you work your way through the tutorials, you should end up with a good understanding of the relationships between the various components.
    David Koch
    Administrator richard.binning's Avatar
    2015-12
    In the foothills of the appalachians
    2,260
    Quote Originally Posted by crenninger
    Cheryl
    Hi Cheryl,
    I searched the help for your specific search term listed above and could not find it in either the 2004 help or 2005 help files. What you really need to search on is "Custom Tags". Essentially, you will have to perform the following tasks as shown in the flow chart from the help file:
    Creating a custom tag
    The docs and brain dumps listed by David will give you all the background you need to create any custom tag desired. For more information on extending custom capabilities into the schedule tables themselves, look for the following brain dump by Scott Arvin of Autodesk titled: Property Data Enhancements. It was released in March of 2003. It should be available on Chris' site or Rob Starz' site.
    If you have Paul Aubin's book "Autodesk Architectural Desktop, An Advanced Implementation Guide", you will find what you need in Chapter 6. Even though this book was written for ADT 3.3 you will find it invaluable in truly understanding the inner workings of ADT. Much of it is still applicable to 2004 and 2005.
    If you care to share what you are working on, perhaps one of us has already created it or can assist you in the next step.
  1. Custom Window Tags
    By merge in forum Revit Architecture - General
    Last Post: 2011-03-30, 10:59 PM
  2. Custom Elevation Tags:
    By jj mac in forum Revit Architecture - General
    Last Post: 2010-09-17, 04:37 PM
  3. Creating Custom Tags
    By aubry27 in forum ACA/AMEP Tips & Tricks
    Last Post: 2010-02-14, 04:02 AM
  4. Need help w/ custom tags for footings
    By tmad101185 in forum Revit Structure - Families
    Last Post: 2008-01-04, 02:22 PM
  5. Custom Tags and Custom Tag Positioning
    By bcox in forum Revit Architecture - General
    Last Post: 2004-05-04, 02:52 PM
