That is an ADT term.
I am using Autodesk Building Systems 2007.1
PN is SSM on steroids.Originally Posted by Chris.N
Yes it is possible, what you want to do is in your dynamic block is create the appropriate attributes and as the default insert a field, when you are prompted select AEC PROJECT as the field category and then use the appropriate field name.
If you have custom project details they can be found under Project Details and then search through the list in the middle of the dialog box for the appropriate one.
Hope this helps, sorry if it isnt clear
