Thread: Family types in families
    2004-07
    179
    Question Family types in families
    Hello,
    I wanted to know when we create a family of particular dimensions,then we label them & add label parameters to them,then in the family type category when i try putting different dimensions for for the parameters i.e by creating new family types ,it gives me errors and does not take a different dimension except for the one in which the drawing was made.. could anyone help me out with this.
    Regards,
    Aliya
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Family types in families
    Try flexing each parameter tied to a dimension to see what errors you get. They have to be resolved before you can continue. Typically they are constraint issues. A good practice is to just dimension to reference planes, flex these to make sure you get the expected results, & then construct the solid geometry, constrained to the reference planes.
    If you can't figure it out, post the family & someone will help you.
    I could stop if I wanted to ita's Avatar
    2003-09
    Perth Australia
    365
    aliya,
    I have found that there are times this occurs if you origionally create the parameter names in the family editor and give those params numerical values that do not match the values created on the drawing, you can get this type of error message.
    In those events, unlink the dimension to the param name. change the Family Editor value to zero and then apply the param name. In some cases there may be different dimension values requiring the same param name in the sketch. If that happens, unlink the names in the sketch, set all the dimesions in the drawing requiring that name to the same dimesion value, set the Family Editer name to a zero value and then reapply the param name.
    Also, I usually find this happens if the sketch is really not constructed properly or there is some "flaky" construction logic in the dimensioning. Make sure you give the dimensions space to flex.
    A further trap for beginners (and I did this a lot ) and that is to dimension the same object more than once in different views. For instance you may dimension the cabinet height in a rear elevation and a side view - doing that will create the same error maessage.
    2004-07
    179
    Smile Re: Family types in families
    Thanx to u both ,reference lines was the problem, solved it.
    regards,
    Aliya
  1. 2012: Families - Different template types
    By ccenergy in forum Revit Architecture - Families
    Last Post: 2012-01-21, 12:51 AM
  2. Family Type Parameter sucking in family types from within Project.
    By nharburger in forum Revit Architecture - Families
    Last Post: 2010-09-08, 06:05 PM
  3. Controling Nested Family Types by A Type Parameter in the Host Family
    By The-Revit-MEPlumbing-User in forum Revit MEP - Families
    Last Post: 2010-09-07, 06:01 PM
  4. Edit Family from within project - lose Family Types
    By dfriesen in forum Revit Architecture - Families
    Last Post: 2005-08-17, 09:09 PM
  5. Family types in families
    By aliya14 in forum Revit Architecture - General
    Last Post: 2004-07-20, 11:47 AM
