Results 1 to 7 of 7
Thread: Assigning Elevation to a Layer
    2005-09
    VARANASI in India
    338
    Default Assigning Elevation to a Layer
    Is there any method to assign a Level (Elevation) to a Layer so that all object drawn on that layer set on assigned elevation. This may be helpfull in Acad Architecture.
    L.J.Upadhyay.
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Re: Assigning Elevation to a Layer
    Please note I am moving this from the wishlist forum to the ACA 2008 forum.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    Member memetic's Avatar
    2007-04
    18
    I wish.
    I don't think there is any "automatic" way to do this. It would be very helpful though. I usually start the design phase with the entire building in one drawing instead of split up by levels. I usually just end up adding a 1, 2, 3 etc to the layer names to group them. Then, delete the prefix after the model gets split up into separate files per level.
    I don't know if it is just me, coming from modeling apps to ACA (ADT etc), but I still wish there was an easier way to edit the entire model in one file for the design phase when it is most helpful to have the entire building (object) in your "hands" at once to manipulate and look at.
    You should post this in the wishlist forum.
    2002-09
    Madison, WI
    5,688
    If you're going for the massing/elevation aspects, I'd model the exterior as one file and have it span from level to level. Then have the interiors split. Just a thought.
    2007-04
    18
    Yeah, I have tried that too. It works well sometimes. But, many times I need to see and edit the inside spaces in conjunction with the exterior. For example, a school I was designing had a lobby with double/triple height spaces, stairs, elevators, bridge-like walkways, all of which was intimately integrated with the exterior walls.
    I tried very hard to model in separate files, but there was just NO way. And, I definitely am not going to model things twice in two programs (one for design, one for con docs). So, when I need to, I put them together, then take them apart.
    I wish there was an easier way. I also wish modeling was better - like rhino or certain other modelers. It is so frustrating to work in 3d with ACA.
    2002-09
    Madison, WI
    5,688
    Ok then on another thought, set up different view files (1 per floor) and try adjusting the cut plane and the depth. I've gotten that to work before. May not always work though.
    2015-12
    4,730
    Ths can be done, you just need the patience to build the rules for the elevation object to place all the needed linework on the correct component which can have a specific layer assigned to it.
  1. Assigning Layer States to Viewports
    By guitarchitect in forum ACA General
    Last Post: 2012-07-13, 10:04 PM
  2. Layer Based Elevation Control
    Last Post: 2008-10-12, 04:14 PM
  3. Assigning Elevation to a Layer
    By ljupadhyay in forum ACA Wish List
    Last Post: 2007-04-24, 05:03 PM
  4. assigning layer key to new all style?
    By vanderloo5 in forum ACA General
    Last Post: 2005-06-28, 03:15 PM
  5. Re-Assigning Elevation Level Heights - Need Help!
    By razorx1858 in forum Revit Architecture - General
    Last Post: 2004-05-11, 10:15 PM
