It's maddening to try to create a simple part to match the DOT requirements. How do you get it to create an eccentric square base with circular top that is offset to one edge of the base?
This might help. It's a link to the 2008 user guide with a large section on using partbuilder.
http://images.autodesk.com/adsk/files/civil_ug0.pdf
Thanks. I will take a look at it and see if I can figure it out.
