Thread: Part Builder Problems
    2005-09
    Georgia
    82
    Default Part Builder Problems
    It's maddening to try to create a simple part to match the DOT requirements. How do you get it to create an eccentric square base with circular top that is offset to one edge of the base?
    Thanks
    100 Club MMccall.83699's Avatar
    2005-03
    a little off center
    140
    Default Re: Part Builder Problems
    This might help. It's a link to the 2008 user guide with a large section on using partbuilder.
    http://images.autodesk.com/adsk/files/civil_ug0.pdf
    2005-09
    Georgia
    82
    Thanks. I will take a look at it and see if I can figure it out.
  1. CV218-4: Get the Part: AutoCAD Civil 3D Part Builder
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2014-12-01, 04:52 AM
  2. 2012: Part Builder
    By valejandro_ibarra in forum AutoCAD Civil 3D - Pipes
    Last Post: 2013-03-22, 08:24 PM
  3. 2011: Part Builder - Structure Height problems
    By corcad in forum AutoCAD Civil 3D - Pipes
    Last Post: 2012-03-28, 05:13 PM
  4. Part Builder
    By a.navarrete in forum Español - AutoCAD Civil 3D
    Last Post: 2009-04-16, 02:33 PM
  5. part builder
    By wag24 in forum AutoCAD Civil 3D - General
    Last Post: 2008-08-06, 10:14 PM
