Results 1 to 10 of 12
Thread: MVSETUP returns Unknown command
    100 Club jonathanschade's Avatar
    2015-11
    130
    Default MVSETUP returns Unknown command
    I have a user who, when she types in "MVSETUP" at the command line gets an "Unknown command" error. This is a basic AutoCAD command. What can I do to get this command back? Will re-installing AutoCAD be the only solution?
    Thanks
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Default Re: MVSETUP returns Unknown command
    You may be missing the MVSETUP.LSP file. You should be able to find it in your Support directory found in the directory where your AutoCAD is installed.
    0,0,0 The Origin
    8,570
    Just-in-case;-
    Mvsetup is not available in LT.
    2015-11
    130
    I can not find a MVSETUP.LSP in the Support directory, but I did find a MVSETUP.DFS. (?)
    2005-06
    in the upper right corner
    3,507
    Quote Originally Posted by jonathanschade
    You SHOULD have an mvsetup.lsp in you AutoCAD\support folder.
    I have one for every version of AutoCAD I have loaded.
    I don't know what a mvsetup.dfs is, I don't have one anywhere on my machine(?).
    What version of AutoCAD?
    PS, to re-quote "Jaberwok", it won't be in AutoCAD LT.
    2015-11
    130
    I am working with AutoCAD 2006
    0,0,0 The Origin
    8,570
    a .dfs file contains default values. ~shrugs~
    2005-06
    3,507
    Here's a copy of mvsetup.lsp for 2006
    2015-11
    130
    Thanks alot!
    2007-06
    288
    I was having an issue with trying to run mvsetup within a lisp. I type (command "mvsetup") but nothing happens. i can type mvsetp on the command line and it runs just fine. Is there something I am missing within my lisp to call up this other lisp?
  1. 2013: Problem with MVSETUP command
    By CAD Monkey UK in forum AutoCAD General
    Last Post: 2013-09-03, 08:54 AM
  2. AutoCAD LT 2007 Appload command returns - unknown command
    By tbedrich in forum AutoCAD LT - General
    Last Post: 2007-04-10, 02:09 PM
  3. Rectangle command returns - unknown command
    By rhayes.99001 in forum AutoCAD General
    Last Post: 2006-11-27, 02:33 PM
  4. _ai_molc command returns unknown command message
    By jan.pennabecker in forum AutoCAD Customization
    Last Post: 2006-05-19, 12:02 AM
  5. MVSETUP Command not working
    By cconfer in forum AutoCAD General
    Last Post: 2006-02-15, 06:38 PM
