Results 1 to 6 of 6
Thread: Working with Visual Lisp and VBA - pass an object ID or entity handle to VBA
    AUGI Director cadpoobah's Avatar
    2015-09
    Central Ohio
    437
    Default Working with Visual Lisp and VBA - pass an object ID or entity handle to VBA
    I am not a VBA programmer, but am working with one. I have a lisp routine that needs to pass an object ID or entity handle to VBA.
    I know that there are ways to use the USERx# variables to allow VBA to grab something set by VL, but I don't think this will work with an object ID. I've also heard it suggested to use the Blackboard in Visual Lisp. I'm not familiar with that.
    So, rather than spend a whole lot of time spinning my wheels, I'm going to take the efficient (humble) route and ask for help.
    Any suggestions?
    Thanks!
    Turlock, CA
    6,579
    Default Re: Working with Visual Lisp and VBA - pass an object ID or entity handle to VBA
    ObjectId's and Handle's are just strings. USERS should work fine if thats the way you want to do it. I prefer to use vb to get an instance of the VL interface and just run the lisp from vba. Search this forum form vlax.cls for a wrapper class that allows you to work with lisp.
    BTW ,the BB is only available to lisp, not vba...unless you use the method above and then the point is useless. Lisp runs in the document context and so the bb is used to pass variables from one document context to another...all within lisp. VBA doesn't have this limitation.
    C:> ED WORKING....
    LinkedIn
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Quote Originally Posted by Ed Jobe
    Hi Ed Jobe,
    I am afraid that it's long, not string. By the way, is it possible to store data in a custom dictionary using LISP and access it using VBA or vice versa?
    2002-02
    Kansas
    487
    Quote Originally Posted by zoomharis
    Hi Ed Jobe,
    Yes to this one
    2015-09
    Central Ohio
    437
    Thanks for the quick reply, Ed.
    IN this case, I will need to keep it so that lisp calls vba. Does this mean then that I can't use (or don't need) VLAX.cls?
    If I want to pass a Handle to vb (as a string via a USERS# variable), then I assume that vb can use the handle to the select the object it needs. True? How?
    Turlock, CA
    6,579
    See the Developer Guide for the HandleToObjectId and ObjectIdToObject methods.
    C:> ED WORKING....
    LinkedIn
  1. Replies: 4
    Last Post: 2014-11-14, 04:01 AM
  2. CP33-2: A Visual LISP Wizard's Intor to Object Magic
    Last Post: 2013-04-08, 07:20 PM
  3. Object snaps not working in lisp routines in 2012
    By jrp.31023 in forum AutoLISP
    Last Post: 2012-11-01, 06:39 AM
  4. visual lisp editor should be like visual studio
    Last Post: 2011-11-17, 05:33 PM
  5. Dockable Interface, Object Browser, Object handle ideas...
    By Richard McCarthy in forum Revit Architecture - Wish List
    Last Post: 2003-10-08, 05:49 PM
