Thread: Write XData to an entity
    2005-02
    95
    Default Write XData to an entity
    I have a some object to create new. I want to write xdata to an entity. like...
    member size, part no. and member length etc...
    When I am creating a new member (angle) I have to give the member no. and part no. and lenght of member is calculating automatically when the first time intoduce new member.
    when I want to create that member detail drawing in separate. at that time I select object and all three (as above) data will take automatically.
    some one have any idea. how to do it or can anyone give me code.
    Thanx.
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,109
    Default Re: Write XData to an entity
    Here is some code that will attach a list of sublists to an entity or vla-object
    ;Create a list of sublists of your data
    (setq lstOfSublists (list (list "Partnumber" 1)(list "MemberNumber" 2)))
    ;Attach the data using the setxdata funtion
    (setxdata entSelection lstOfSublists)
    ;retrieve the xdata using the getxdata function
    (setq lstOfSublists (getxdata entSelection))
    See routine code below
    Peter
    ; The setxadata function will add a list of sublists to an object as xdata.
    ; The first item in each sublist is a unique string application name
    (defun SetXData (objSelection lstOfSubLists / DataItem lstData
                     intDataType lstOfSublistsDXFCodes lstOfSublistsValues
                     safDXFCodes safDataValues)
     (if (= (type objSelection) 'ENAME)
      (setq objSelection (vlax-ename->vla-object objSelection))
     (foreach lstData lstOfSublists
      (setq lstOfSublistsDXFCodes (cons 1001 lstOfSublistsDXFCodes)
            lstOfSublistsValues   (cons (car lstData) lstOfSublistsValues))
      (RegApp (car lstData))
      (foreach DataItem (cdr lstData)
       (cond    ; Determine the data type and corrusponding DXF Code
        ((= (type DataItem) 'INT)
         (if (> DataItem 100000)
          (setq intDataType  1071)                          ; Long    Data Type
          (setq intDataType  1070)                          ; Integer Data Type
        ((= (type DataItem) 'REAL)(setq intDataType  1040)) ; Real Data Type
        ((= (type DataItem) 'STR)
         (if (or (= DataItem "{")(= DataItem "}"))          ; String Data Type
          (setq intDataType  1002)
          (setq intDataType  1000)
       (setq lstOfSublistsDXFCodes (cons intDataType lstOfSublistsDXFCodes)
             lstOfSublistsValues   (cons DataItem    lstOfSublistsValues)
     (setq safDXFCodes   (listToSafearray vlax-vbinteger
                          (reverse lstOfSublistsDXFCodes))
           safDataValues (listToSafeArray vlax-vbvariant
                          (reverse lstOfSublistsValues)))
     (errortrap '(vla-setXData objSelection safDXFCodes safDataValues)))
    ; Returns a list of sublists that include a application name as the first
    ; Item in every sublist and data for the remaining members
    (defun C:GetXdata ()
     (getxdata (car (entsel "\nSelect object with Xdata: ")))
    (defun GetXdata (objSelection / intCount lstAll lstSub safDXFValues safDXFValues)
     (vla-getxdata objSelection "" 'safDXFCodes 'safDXFValues)
     (if (and safDXFCodes
              safDXFValues
      (progn
       (setq lstDXFCodes  (vlax-safearray->list safDXFCodes)
             lstDXFValues (mapcar 'variant-value (vlax-safearray->list safDXFValues))
             intCount 0
       (foreach intDXFCode lstDXFCodes
        (if (= intDXFCode 1001)
         (if lstSub
          (setq lstAll (cons (reverse lstSub) lstAll)
                lstSub (list (nth intCount lstDXFValues))
          (setq lstSub (list (nth intCount lstDXFValues)))
         (setq lstSub (cons (nth intCount lstDXFValues) lstSub))
        (setq intCount (1+ intCount))
       (if lstSub (reverse (cons (reverse lstSub) lstAll)))
    ; Convert list to Safearray
    (defun ListToSafearray (symVariableType lstValues / safValues)
     (setq safValues (vlax-make-safearray symVariableType (cons 0 (1- (length lstValues)))))
     (vlax-safearray-fill safValues lstValues)
  1. Replies: 6
    Last Post: 2015-08-31, 04:05 PM
  2. Delete XData with a specified application name from a selected entity
    By peter in forum Bridging the Gap: LISP -> .NET -> LISP
    Last Post: 2015-06-09, 03:10 PM
  3. Help me with xdata
    By rdogomes in forum AutoLISP
    Last Post: 2010-09-16, 06:42 PM
  4. How can I write a Xdata to a new fresh entity
    By avinash00002002 in forum AutoLISP
    Last Post: 2007-04-13, 03:38 AM
  5. Proxy Entity Code 310 to Normal Entity
    By KevinBarnett in forum AutoCAD General
    Last Post: 2005-05-26, 07:21 AM
