Results 1 to 8 of 8
Thread: Looking for a LISP routine to plot out a .CTB file with relevant information attached
    I could stop if I wanted to cadd4la's Avatar
    2001-12
    Newport Beach, CA
    397
    Default Looking for a LISP routine to plot out a .CTB file with relevant information attached
    Hello everyone,
    I am in need of a lisp file that will read the set .ctb file in the drawing, then draw a line for all the layer colors, as well as have text of the color name to the left of the line and text of the lineweight above the line. On a 8 1/2x11 sheet.
    Thanks for the help.
    Kyle C.
    Earth
    9,803
    Default Re: Looking for a LISP routine to plot out a .CTB file with relevant information attached
    It's not easy to cram 255 lines with text on a Letter sized sheet, and have it be legible.
    R.K. McSwain | CAD Panacea |
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,032
    Plus, AutoLISP cannot read the contents of CTB or STB files. Therefore, the lineweights information of each color cannot be read.
    Earth
    9,803
    I think OP was talking about getting output like this, which is possible.
    In other words, to visually see the lineweights, not necessarily document the size in inches or mm.
    I read "text of the lineweight" to mean some text (the name of the color) printed at the lineweight of that color.
    You can't really do this however because the really thick lines would just make a blob of the text, so I just use TTF for the text in mine.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,643
    Could you attach that drawing?
    You can use Autocad CTB (or STB) online viewer to see it shown in a web page.
    2001-12
    Newport Beach, CA
    397
    Tom,
    Thanks, this will work.
    Cadd4la
    2009-11
    5,688
    This may help:
    Quote Originally Posted by BlackBox View Post
    A while back I took on a similar challenge, and ended up recreating a drawing to depict various CTB's, which may save you some effort... See the attachment in this old post; here's a small screen shot:
    Cheers
    Computer Specs:
    Cairo - no, not Illinois
    5,054
    Here's a sheet I use for matching the pen weights to client requirements. This particular example is showing NavFac pen weights and color, and will plot properly only with the NavFac ctb from the Navy.
    As I deal with other client standards, I'll set up a similar sheet for their requirements. Kind of a PITA to do it manually, but with a small number of clients that require uniqe standards, it's acceptable.
  1. New Plot Device - LISP Routine
    By techsupport.161645 in forum AutoLISP
    Last Post: 2009-01-09, 09:55 PM
  2. Replies: 2
    Last Post: 2007-05-11, 11:25 AM
  3. Is it possible to draw attached image via a LISP routine?
    By BRENDA_GZZ_GOMEZ in forum AutoLISP
    Last Post: 2007-04-16, 09:00 PM
  4. Replies: 6
    Last Post: 2006-08-08, 04:02 PM
  5. How to convert Plot Lisp routine to VBA
    By ian.cook in forum VBA/COM Interop
    Last Post: 2006-07-10, 07:02 PM
