Results 1 to 10 of 11
Thread: Routine to change Attributes color to Bylayer not working in AutoCAD 2008
    2001-10
    Defragging the internets.
    350
    Default Routine to change Attributes color to Bylayer not working in AutoCAD 2008
    This is one for changing attributes to color bylayer. I got it ether here or on Autodesk forums.
    1.
    (if (ssget "x" '((0 . "INSERT")(66 . 1)))
        (progn
          (setq ss (vla-get-activeselectionset
    		 (vla-get-activedocument
    		   (vlax-get-acad-object))))
          (vlax-for blk ss
    	(setq atts (vlax-invoke blk 'getattributes))
    	(foreach att atts
    	  (vla-put-color att 256)
    2nd
    (setq doc     (vla-get-activeDocument (vlax-get-acad-object))
            layouts (vla-get-layouts doc)
      (vlax-for layout layouts
        (vla-put-showPlotStyles layout (if state :vlax-true :vlax-false))
      ;(vla-regen doc acAllViewports)
    Any help to make it work again would be greatly appreciated.
    Chris
    2006-11
    UTAH
    135
    Default Re: Routine to change Attributes color to Bylayer not working in AutoCAD 2008
    This is now done natively in 2008 with the Setbylayer command.
    2001-10
    350
    Quote Originally Posted by mike.127154
    I read about that on one of the blogs somewhere but could find any reference to it once we install 2008.
    Chris
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by FRAMEDNLV
    Chris
    From the Menu:
    Modify => Change to Bylayer
    2004-08
    Iron Station, NC
    3,198
    Quote Originally Posted by Tom Beauford
    From the Menu:
    or type setbylayer
    2001-10
    350
    Thank you guys for pointing out the "setbylayer" feature.
    I was wondering why the original lisp was failing. I have about three different lisp routines that are failing and they all use the vla/vlax in the lisp.
    Chris
    2001-03
    Tallahassee, FL USA
    3,667
    Chris
    I'm sure someone could debug it if you posted the whole routine.
    2004-08
    Iron Station, NC
    3,198
    i would also make sure you have vl-load-com in your commands
    2001-10
    350
    (VL-LOAD-COM)
    That seems to have fixed it. I'll have to look at my startup lisp to see where it was loading and where I stopped loading it. For now I just added it to the beginning of our acad.lsp.
    Chris
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    (VL-LOAD-COM)
    Chris
    It is only needed to be loaded once. Subsequent calls do not affect anything.
  1. Changing attributes color bylayer...?
    By aport in forum AutoCAD LT - General
    Last Post: 2018-09-11, 02:18 PM
  2. Command to Change Color of Mtext to BYLAYER
    Last Post: 2010-01-22, 10:58 PM
  3. Change Attributes to color ByLayer
    By rmk in forum AutoCAD General
    Last Post: 2008-01-22, 12:24 AM
  4. How to change block w/ attributes bylayer
    By aport in forum AutoCAD General
    Last Post: 2008-01-16, 04:59 AM
  5. Replies: 2
    Last Post: 2007-02-12, 05:04 PM
