Results 1 to 7 of 7
Thread: Adding together the area value of two Attributes, place result into a third Attribute
    2003-08
    Tijuana
    225
    Default Adding together the area value of two Attributes, place result into a third Attribute
    I want to create a block with two attributes that read the areas of two Polylines using fields, and with a third attribute with a field that adds up the areas returned by the previous attributes. Can someone give an example of the required formula syntax?
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Default Re: Adding together the area value of two Attributes, place result into a third Attribute
    This thread has some field calculations using block attribute values. In your case, insert the two attribute values one by one in the formula column seperated by '+' operator to get the sum.
    To insert block attribute values inside formula column, Right click --> Insert Field --> Choose 'Object' field category --> Select Block then select the attribute listed there.
    2003-08
    Tijuana
    225
    Thank you. I still haven't got what I need. I want to make a formula work inside a third attribute in the same block. Is that possible? I don't want the sum to be made on a table.
    100 Club wroebuck's Avatar
    2004-07
    Chico, CA
    158
    That is possible. link the first 2 attributes to the objects in the drawing, pulling the areas. In the third attribute, use the formula category, right click in the formula window, pick object category, click the block you are working on, select the attribute, value & add them together. Drilling into attributes like this requires 1 more regen to update the field.
    2003-08
    Tijuana
    225
    Thanks, that work Wroebuck. However, the field and/or formula has to be worked out manually. Does anyone know if it is possible to "predefine" some sort of code for the third attribute that would add up the areas pulled out by fields on attributes 1 and 2?
    100 Club jgrande26's Avatar
    2001-10
    Down the rabbit hole
    196
    You can try this thread too.
    2007-12
    32
    Just found this thread.
    I want to do something similiar but need to undrstand how this works.
    How does the formula know where it is getting the data from. How can I add additional inputs to the same formula, is it as simple as 1+2*3?
    I also need to use IIf statements too.
    Bill
  1. 2013: GIA Area and Room Area not adding up
    By jcoops39700321 in forum Revit Architecture - General
    Last Post: 2015-05-08, 05:07 PM
  2. Replies: 2
    Last Post: 2012-01-31, 07:02 PM
  3. Help adding attributes that are a field
    By dkochel in forum Dynamic Blocks - Technical
    Last Post: 2007-10-30, 08:20 PM
  4. Adding Attributes
    By michael.viscetto65572 in forum AutoLISP
    Last Post: 2007-08-20, 11:10 AM
  5. Can I place an area tag outside the area called out?
    By blumarble in forum Revit Architecture - General
    Last Post: 2006-05-06, 08:26 PM
