Thread: Door Window Vent Assembly
    2005-09
    VARANASI in India
    330
    Default Door Window Vent Assembly
    I have to set a door window venilator assembly in a wall space 8' wide & 8'8" high. A single 39"x84" door at one side & remaining width by a glazed window of sill ht.6". Remaining height is to be filled with glazed ventilator. Should I use curtain wall for this setup ? Or there is any door window assemly family in Revit like ADT
    2015-12
    Metro Boston, ,MA
    5
    Default Re: Door Window Vent Assembly
    If I understand you correctly, the way I have done this is to add the glazing above the door the same way as you created the sidelight. The door family where I used this method is attached.
    2005-09
    VARANASI in India
    330
    Thanks eclark
    This is what, I looking for. Mullions for window & Vent is only req. which can be added now. Thaks ones again.
    2015-12
    Metro Boston, ,MA
    5
    I'm glad I was able to help you -- it was my first post to the forums so I was a bit nervous!
    Elizabeth
  1. Creating a door/window assembly
    By sharla in forum ACA General
    Last Post: 2008-01-14, 04:39 PM
  2. Door/Window Assembly
    By leothebuilder in forum ACA General
    Last Post: 2007-11-29, 11:45 PM
  3. Door Window assembly help
    By kstump in forum ACA General
    Last Post: 2006-04-05, 01:23 PM
  4. Door/Window Assembly
    By swaink in forum ACA General
    Last Post: 2004-12-21, 04:10 PM
  5. WINDOW aSSEMBLY WITH OFFSET DOOR
    By jasontirone in forum ACA General
    Last Post: 2004-12-17, 03:44 PM
