Thread: Linking Fields between tables
    Member cadmancando's Avatar
    2015-11
    Arlington, WA
    24
    Default Linking Fields between tables
    Anyone have any success with this?
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Default Re: Linking Fields between tables
    Can you tell us what exactly you are trying to achieve, if possible with an example?
    2015-11
    Arlington, WA
    24
    Sure.....
    I've created a table, which has a sum field at the bottom.
    I have another table on another layout which has a field which looks at the first tables summary field and places the same value in the second table.
    I guess I could say...."I want to link a field in one table with a field in a second table"
    Hmmm....
    Idea maybe....
    Can you use a diesel expression to set the setvar USERR1 to the value of the first field?
    Then I can retrieve the USERR1 value to the field of the second, third, .... table(s)
    2015-11
    Arlington, WA
    24
    Figured it out....
    The field of the second table must state:
     =Table(2130252600).A5
    where
    2130252600 = Table ID
    A5 = Field of table
  1. Fields within Tables
    By roundbox52 in forum ACA General
    Last Post: 2009-11-04, 03:53 PM
  2. ACA 2009 tables linking
    By g.ryall in forum ACA General
    Last Post: 2009-03-23, 06:03 PM
  3. Tables Fields & the SSM
    By KGC in forum AutoCAD Tables
    Last Post: 2007-08-24, 02:07 PM
  4. VBA fields and tables
    By MikeJarosz in forum VBA/COM Interop
    Last Post: 2006-11-16, 08:58 PM
