Results 1 to 6 of 6
Thread: Multileader style location?
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Multileader style location?
    When you first use multileader in a legacy drawing, it will go ahead and pull in the leader heads. WHERE are these coming from? Would be nice to know so one could change them...
    I suppose they use the same content as the dimensions do, but it would be nice to clarify this.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2015-12
    4,730
    Default Re: Multileader style location?
    Have I asked a redundant question or is it super hard to find this info...
    13,656
    Hi
    Via the Standard MultiLeader Style.
    Take a look at the Multileader Style Manager dialog box...
    Command: _.MLeaderStyle
    Have a good one, Mike
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Quote Originally Posted by Steve_Bennett
    it appears to be the latter. if you explode a multi-leader, it breaks down to a block called _TagHexagon (or similar) - i did a search of my harddrive for that and came up empty, so they are nested somewhere.
    however, if you search for "leader" you will get a number of results - if you poke around a bit there are several files that have the various blocks in them -
    C:\Program Files\AutoCAD Architecture 2008\ContentPacks\cp_BSD_Imperial_Base\guides.cab
    C:\Program Files\AutoCAD Architecture 2008\Sample\Dynamic Blocks\Multileader Tools.dwg
    C:\Documents and Settings\User\Application Data\Autodesk\ACD-A 2008\enu\Properties\Autodesk.AutoCAD.DatabaseServices.MLeader.xml
    2015-12
    4,730
    Quote Originally Posted by Chad_C
    Very interesting. No wonder I couldn't find them! Thanks - that is what I was looking for. I knew those blocks had to be coming from somewhere.
    2006-04
    1,129
    let me know what you find out. i always like new things to tinker with - and wouldnt mind trying to add in some additional shapes.
    now if i could just figure out how to get DB's working with MLeaders..
  1. MULTILEADER STYLE
    By Moubis106433 in forum AutoCAD General
    Last Post: 2015-07-10, 02:09 AM
  2. Multileader placement location.
    Last Post: 2014-11-14, 02:51 PM
  3. Replies: 1
    Last Post: 2012-04-16, 11:09 AM
  4. Replies: 0
    Last Post: 2011-10-04, 11:21 PM
  5. Modify Multileader Style - Help please
    By john.lincoln in forum AutoCAD General
    Last Post: 2008-12-29, 10:53 PM
