Thread: Viewing surface in Object Viewer Problem
    2005-09
    Georgia
    82
    Default Viewing surface in Object Viewer Problem
    I wasn't sure where to put this, but figured it should be here.
    I have created a corridor and made a surface from it. When I go into the object viewer to look at and make sure it hasn't got weird things going on, I can see the rendering for the asphalt from the top view. However, when I rotate the view, I can see the rendering doing really weird things. It matches the top view but when rotated, it has totally different elevations. I've tried to capture a shot of it but once I rotate it the rendering disappears when I let go of the mouse button afterwards. Can someone tell me what the heck is causing it? The surface elevations have so far matched what they should be when I've checked along the corridor.
    2010-08
    6
    Default Re: Viewing surface in Object Viewer Problem
    make sure the surface layer is on in addition to the layer SRF-VIEW layer.
  1. 2015: Civil 3D - System Variable - Object Viewer, Surface Properties etc
    By EarthShifter88 in forum AutoCAD Civil 3D - General
    Last Post: 2015-05-27, 02:51 PM
  2. 2013: object viewer
    By ala.balaportocala256381 in forum AMEP General
    Last Post: 2013-06-26, 06:28 PM
  3. New Object Viewing
    By gsteffen642486 in forum ACA General
    Last Post: 2012-10-19, 04:41 PM
  4. 2011: Lost Control of Viewing 3D object
    By yusof.ghani in forum AutoCAD 3D (2007 and above)
    Last Post: 2011-11-22, 03:02 AM
