Thread: Omit Door from Schedule
    2006-12
    3
    Default Omit Door from Schedule
    I want to create a door schedule and not schedule some of the doors such as bathroom stall doors. I do not think this is a phasing question so the question is how can I create a door schedule and select what doors I want to omit?
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Omit Door from Schedule
    Filters.
    Select or add a parameter with a common value for all the doors you want to eliminate (or show) and then filter the schedule with that parameter...
    2006-12
    3
    thank you!
    2004-06
    Memphis TN area
    7,048
    We usually use filters within the schedule itself (not the newer filter function that came about in the previous version). If you have doors you do not want to schedule, just stick an "x" or whatever character you want before the door number, and then tell the schedule to not include doors whose numbers begin with that character.
    2006-12
    3
    Thanks! That works perfectly.
  1. 2012: Door Schedule Issue- Rogue Door Tag
    By tra1133 in forum ACA General
    Last Post: 2012-12-04, 06:09 PM
  2. 2013: Door Family - Frame Types - Door Schedule - Legend Component
    By bmaxwell143848 in forum Revit Architecture - Families
    Last Post: 2012-10-29, 01:45 AM
  3. 2011: Face Based Door Family - To & From Door Schedule
    By eddie.kempf in forum Revit Architecture - Families
    Last Post: 2012-03-01, 04:29 PM
  4. Nested Door Families and Door Schedule Issues
    By d.branch in forum Revit Architecture - Families
    Last Post: 2010-11-19, 10:41 PM
  5. How do I omit doors from being included in my schedule?
    By keith.114973 in forum ACA General
    Last Post: 2007-05-03, 06:41 PM
