Thread: Unable to successfully rotate attributes in Block with Annotative scaling attached
    2001-10
    Defragging the internets.
    333
    Default Unable to successfully rotate attributes in Block with Annotative scaling attached
    I can see there are going to be some pitfalls with annotative objects.
    I just gave it a try with a block that has a circle and two attributes. I did a block edit and applied annotation to the block and saved. At this time things look OK. Then I inserted the same block and it came in lager the the original. No problem there is going to be a big yo-yo thing happening with the actual scale. So I go back and block edit and scale everything down by 1/96. This fixed my new Yo-Yo. Now I try torient to rotate the attribute and guess what happened.................my string broke or something because my text bounced up 96 times larger. I then tried attedit and was able to rotate on attribute value at a time with out it changing size.............but it seems to rotate around BL instead of the defined center justification.
    I tried with torrient and it freaks out the attribute size. Tried attedit and it rotates from the wrong justification.
    I also tried annoreset and it leaves the attribute in the last position and moves everything else to its original position
    I would also like to know how to apply a set of custom annotation scales to objects with out going threw the dialog box (lisp/script).
    Chris
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Default Re: Unable to successfully rotate attributes in Block with Annotative scaling attached
    can you post the block / a drawing with the block?
    battman / attsync may help out also.
    ive found a few quirks with annotative blocks and going back and forth between annotative and non-annotative. most i have managed to muddle through by trial and error.
    This aggression will not stand. Man.
    2001-10
    333
    I tried attsync and it didn't work (don't recall the results).
    I don't have any specific file saved with this scenario. I was just trying out the new features at this time.
    I'm trying to get a handle on things to see if I can update our block files (selectively).
    Chris
  1. Dynamic Block Annotative Scaling
    By sovby254640 in forum Dynamic Blocks - Technical
    Last Post: 2012-08-16, 08:25 AM
  2. Replies: 18
    Last Post: 2010-02-11, 09:54 PM
  3. Attribute in Block - Annotative Scaling
    By agoodmansen in forum ACA General
    Last Post: 2008-10-28, 09:38 PM
  4. Annotative Block Scaling Problem.
    By Eddy B in forum AMEP General
    Last Post: 2008-04-30, 08:56 PM
  5. Replies: 0
    Last Post: 2008-03-12, 04:26 AM
