Results 1 to 7 of 7
Thread: Is there a variable by which I can get font file location?
    Member rajat_bapi_mallick's Avatar
    2005-08
    Kolkata, INDIA
    40
    Question Is there a variable by which I can get font file location?
    Hi !
    Is there any variable by which I can get font file location ?
    - Rajat
    India
    2003-11
    277
    Default Re: Is there a variable by which I can get font file location?
    Quote Originally Posted by rajat_bapi_mallick
    Hi !
    - Rajat
    India
    Hi rajat,
    How about this code
    (setq file "C:/Program Files/AutoCAD 2005/Fonts")
    (getfiled "Select a font file" file "" 0)
    Earth
    9,803
    Quote Originally Posted by Adesu
    Hi rajat,
    How about this code
    I think the OP is wanting to find out where AutoCAD is looking for fonts.
    Your code only looks in a particular directory which may or may not exist.
    R.K. McSwain | CAD Panacea |
    Earth
    9,803
    Hi !
    - Rajat
    India
    No, there is not a variable. AutoCAD will search all the paths in the support file search path for SHX fonts. You will have to query each of these paths.
    The following code will return the support file search paths (as a semicolon separated string)
    (vl-load-com)
    (vla-get-SupportPath
      (vla-get-files
        (vla-get-preferences
          (vlax-get-acad-object)
    2005-08
    Kolkata, INDIA
    40
    Thanks.
    But I need windows default ".TTF" font file location.
    -Rajat
    Earth
    9,803
    Thanks.
    -Rajat
    Ok. You didn't say that in your original post.
    This should work.
    Environ("systemroot") & "\Fonts"
    2005-08
    Kolkata, INDIA
    40
    Thanks.
    It really works.
  1. 2012: Japanese font files (SHX) location
    By cadman_99 in forum AutoCAD Customization
    Last Post: 2012-07-20, 04:09 AM
  2. Using Environmental Variable for Source Location
    By heath.simone in forum Revit - Platform
    Last Post: 2012-06-05, 04:43 AM
  3. Replies: 5
    Last Post: 2010-06-04, 06:45 PM
  4. Update font used in multiple dimension styles to one common font file
    By tomasz.stachowiak in forum AutoCAD General
    Last Post: 2007-03-22, 08:54 AM
  5. Swap old custom font file for new font file
    By dgalloway in forum AutoCAD Customization
    Last Post: 2006-02-02, 03:09 PM
