Thread: Plot a Multi-Sheet DWF with Landscape sheets and Portrait sheets
    100 Club KansasCAD's Avatar
    2002-02
    Derby, Kansas
    114
    Question Plot a Multi-Sheet DWF with Landscape sheets and Portrait sheets
    Hello,
    I have a map of our County and I have Layouts for each City. Two of the layouts have the title block in portrait mode because of their length North & South. All of the rest are Landscape. I want a multi-sheet DWF so we can jump to any town. Is there a way to plot a multi-sheet DWF file with two of the sheets in portrait mode? It seems that I can have different page setups for these layouts but then I don't see how to make it multi-sheet.
    Thanks,
    Daryl
    9,804
    Lightbulb Re: Plot a Multi-Sheet DWF with Landscape sheets and Portrait sheets
    Are you saying that you have tried plotting this set of layouts and it fails, or that the output is multiple, single-sheet DWF files?
    To create a single, multi-sheet DWF:
    In the Publish dialog, click on "Publish Options", then under "General DWF options", find the DWF type field and make sure it's set to "Multi-sheet DWF"
    If you are using 2008, see also the PUBLISHCOLLATE sysvar, but in my test, if you do the above steps, this sysvar is ignored.
    2002-02
    Derby, Kansas
    114
    Default Re: Plot a Multi-Sheet DWF with Landscape sheets and Portrait sheets
    Thanks for the reply,
    I just figured it out. I thought that when I tried the last time that it cut off the portrait. I set each drawing to its correct page setup and tried it again and it worked this time.
    Thanks,
    Daryl
  1. Can ABS 2007 tell the difference between Portrait and Landscape
    By henrik.langkjar in forum AMEP General
    Last Post: 2007-04-20, 04:54 PM
  2. Replies: 4
    Last Post: 2006-10-24, 09:45 PM
  3. Plot DWG to PDF with Multi-Sheets
    By ByLMC in forum AutoCAD Plotting
    Last Post: 2006-06-01, 03:15 PM
  4. Plot Portrait / Landscape problem
    By Spenner in forum AutoCAD LT - General
    Last Post: 2006-01-30, 08:08 PM
  5. Landscape or Portrait. Why won't it stay?
    By amy.stuart in forum AutoCAD Plotting
    Last Post: 2005-01-17, 09:24 AM
