Follow the same steps as Acad 2006:Clean - Select 3D Solid - Select the Imprint object, but the Imprint 2D object still there
For Acad 2006, it work but not in Acad 2007
Anyone can help me?
Jack Cheong
Anyone can help me?
Jack Cheong
Do you mean removing an imprint from a solid? If so you can use the ctrl key to select all the edges and the hit the del key.
Thanks!!! It workOriginally Posted by Steve.Sanderson(UK)
Jack Cheong
Hi xudong, Welcome to AUGI
Does the solution in my post above not work?
Also from Autodesk: ID: TS1060039 Removing imprinted objects from 3D solids
Hi Steve,
The "ctrl+select+delete" works. But I want to know why the clean doesn't work. Can you find out?
Thanks for your answer,
Xudong
use "clean" to remove the imprinted.
xudong
