hey people,
I have a question about the transperancy of locked layers. At the moment I can barely see the locked layer, how do I turn the transperancy off so i can see the locked layer?
Thank You,
Jamie
hey people,
Thank You,
Jamie
When you start the LAYISO command, select SETTINGS. Next, choose LOCK then set the variable to what you want the fade percentage to be. I like something in the 60-70% range myself. Also, if you use the pallets, the layer pallet has a slider just for this purpose. Check out this thread for a little more info.
Thanks very much CADDmanVA!
Not a problem, glad I could help!
