Summary: The ability to customize the sheet set list table.
Description: The Sheet list table should be more customizable/user friendly.
How Used: Right now, using Spreadsheets for DWG/Sheet lists is a far more productive way to get them done, but I wish that was not so since the idea behind the Sheet List Table is an incredibly good one...
What needs to happen to make them more useful to the average user is actually fairly straightforward...
1. Allow custom cell data to stay where you entered it when updating the Sheet List table. Sometimes there's quite a bit of it and having to manually re-enter with every update is too time consuming.
2. Allow the selection of which sheets are to be included in the Table. Currently, the best way to do this is to manually remove the contents of the cells containing that data, which leaves "holes" in the table... Not only is that not acceptable in terms of appearance, but (again) when updating the table you have to clear those cells another time...
Implement those 2 things, and it's doubtful the Sheet List Table will be overlooked by anyone anymore...
Feature Affinity: Sheet Set Manager
Submitted By: Michael Ritchie on April 12, 2007
