Summary: The ability to set draw order precedence via a layer property.
Description: Add setting for layer properties to control entity display order precedence.
How Used: When several items from separate layers overlap, it is rather tedious to get the proper display order. Instead if the layer properties could control the display order it would be much easier. For instance if a dimension layer was always displayed on top of object lines or the hatch layer was always behind object lines.
The Layer Properties Manager could either use an absolute numerical listing (with 1 being the highest priority) to determine overall precedence or a relative precedence to another layer (such as "always in front of Object layer" or "always behind Dimension layer").
Feature Affinity: Draworder
Submitted By: Phil Tingley on May 24, 2007
