I'm designing studios with Revit, so I deal with a lot of difficult angles. One of my problems is trying to dimension anything that doesn't lie on the x,y,or z axis. Say a line from 0,1,1 to 3,2,2. I need to communicate to the person exactly what the dimensions should be when his tape hits the framing. I can do this with Sketchup (see jpeg), but not Revit (take a look at A101 in the attached project).
Even in a 3d view, the dimension will snap to an axis. If you check the properties of the line, you'll see that it is actually 9'6" long. But not according to any dimension I try to put on it.
Regards,
Dean Klear
