Firstly sorry if this should be in a more relevant forum sub branch, but I couldn't find a branch for Design Review
I have installed the latest Design Review 2008 and also the latest Trueview
I would like to setup Design Review so that non-caddys can open DWG files with Design review and look at the drawing and possibly take measurements from the drawings which is all achievable with Design Review
However when I import with design review (which then externally publishes with Trueview), any attached xrefs are not being published (note these xrefs are also overlayed into the drawing and not attached (company standard)
But if I create the DWF from within Trueview the DWF comes out fine.
Also by default when you import a DWG to DWF in Design review it creates both a Modelspace and a paperspace view
Can anyone help me with how to change the default settings of the DWF plotting that is done within, I cannont find anywhere to get this to work for me
I could get them to first open the drawings in Trueview batch print the drawings they would like then open them in Design View. But if I can use the import option from within Design Review this would eliminate that step
Thanks
