Thread: AutoCAD 2004 extra lines appear in DWF plots
    2002-01
    CNY
    27
    Default AutoCAD 2004 extra lines appear in DWF plots
    When i plot one of my layout tabs in a multi sheet drawing i get extra lines..arcs to be exact. I have checked everything but they aren't there on the drawing, I can plot a pdf and they aren't there, i have exploded all blocks, made sure all layers were on, i have used publish and plotted the tab using DWF6 eplot.pc3 in both Autocad 2007 and 2008 and in Mechanical 2007 and 2008. I get the same results, Another person plots it in Autocad2004 and its Fine.Any ideas what is causing this? attached is the dwf and pdf that shows the large arcs.
    I downloaded the latest dwfwriter and when i did the problem lines went away. I believe it must be in the dwfplot9 drivers that 2007 and 2008 use, Autocad 2004 uses dwfplot8 heidi drivers with the same pc3 file. Anyone seen problems with these drivers?
    I could stop if I wanted to scott.sheppard's Avatar
    2005-07
    Scottsdale, Arizona
    239
    Default Re: AutoCAD 2004 extra lines appear in DWF plots
    The attachment does not view for me. If you can supply the DWG and DWF, I can log a defect.
  1. AutoCAD 2007 DWG to PDF plots with Black Bands/Lines
    By Brent.Reeves in forum AutoCAD Plotting
    Last Post: 2011-02-25, 05:06 PM
  2. Removal of extra curved lines when plotting
    By kberger in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-11-09, 09:47 PM
  3. Excel file in AutoCAD 2004 Plots upside down
    By dluzius in forum AutoCAD General
    Last Post: 2006-12-04, 03:48 PM
  4. AutoCAD LT 2004 - Scalable date stamp on plots
    By ned.rapp in forum AutoCAD LT - General
    Last Post: 2006-08-15, 01:58 AM
  5. Text Plots differently between 2004 and 2006
    By jgratton in forum AutoCAD Plotting
    Last Post: 2006-05-01, 10:44 PM
