Summary: Ability to similtaneously show both inch and metric dimensions for unthreaded holes. inch (metric)
Description: Alternate dimension in hole note. I would like to show the inch equivalent of a metric hole (or vice versa) diameter, depth, and any attached tolerances
How Used: For example: I may design a part to accept a 5mm dowel pin. However, most local machine shops in the U.S. use inch units. Therefore, the hole note needs to reflect both metric and inch units; inch for the machine shop and metric for the assembly shop.
Feature Affinity: Other
Submitted By: James Zamora on May 30, 2007
