in the attached file are 2 blocks that as far as i can tell are the same in terms of properties. the text size in the block is 3/32" - so when scaled it will print at that size. property wise, both are annotative, unitless and have the same anno scale applied. however the block on top is not scaling correctly, and for the life of me i cant figure out why. it hopefully would be a better replacement for the larger block that i was having problems with, but it obviously is having its own issues.
is this just a case of the gnomes and i should remake it again? or is there some reason it isnt working that i have just over looked?
edit - probably would be helpful if i attached the drawing.
