Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Object properties palette not showing selected Objects properties
    100 Club timothyjturner's Avatar
    2005-09
    Columbus, OH
    101
    Default Object properties palette not showing selected Objects properties
    For some reason I can not double click an object and view its properties... no matter what object I click, the properties palette shows the same information, which seems to be general drawing properties. Any idea what is going on here?
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Object properties palette not showing selected Objects properties
    Quote Originally Posted by timothyjturner
    Is your PICKFIRST system variable set to 1?
    Tim Creary
    S&D
    DILLIGAF
    2005-09
    Columbus, OH
    101
    yes and dblclkedit is on as well.... the properties window actually does come up.. it just does not contain information on my object, just general info that never changes instead.
    Lost
    1,473
    Have you ran any registry cleaners lately? If so, a repair may be in order.
    Tim Creary
    S&D
    DILLIGAF
    2005-09
    Columbus, OH
    101
    No, but I did attempt to install a third party (allen bradley) autocad extension. I later found out that the extension was only supported up to 2005. I suppose its possible the installation attempt could have had an effect.
    Lost
    1,473
    I'm not sure that would do it...
    Does it show what kind of object is selected, but none of the info for that object, or does it say No Selection?
    If the prior, maybe have a look at Properties palette blank after selecting object KB article and see if it applies.
    Tim Creary
    S&D
    DILLIGAF
    2005-09
    Columbus, OH
    101
    It reads No Selection
    0,0,0 The Origin
    8,569
    Which usually means that Pickfirst=0.
    John B
    2015-12
    288
    That is not necessarily the case. I have had this happen on 2006 many times, but not yet on 2008, thankfully. And my sysvars did not change prior to this occurring. Most every time, the only fix was a repair of the installation, with a full re-install being the last option.
    I would like to know what your fix is.
    AUGI Director scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    Quote Originally Posted by Bunny
    Not necessarily...but usually the case.
    Why draw straws? Just draw one straw and array it.
    Scott Wilcox - Edmonton, Alberta
  1. attributes not showing in Properties palette
    By feargt in forum AutoCAD General
    Last Post: 2012-04-17, 05:05 PM
  2. 2012: Attributes not showing in Properties palette
    By tawfik72 in forum AutoCAD General
    Last Post: 2012-04-17, 05:02 PM
  3. Layer filter for currently selected objects in layer properties palette
    Last Post: 2010-06-09, 01:16 PM
  4. Unable to change selected Object properties via toolbars
    By roygoncalves in forum AutoCAD General
    Last Post: 2007-02-08, 10:03 PM
